Many have asked "Where are the Air conditioning drain holes? I can't find them"
so today whilst under the D2 I took some pics ( I couldn't get closer pics due to limited room, but this should guide you.)
pic 1. Drivers side the arrow follows the front tail shaft uni joint at the transmission end, if you draw a line along it and look up on the transmission tunnel immediately above it you will see the out let drain on the transmission tunnel.
Pic 2 shows the actual drain hole.
pic 3. Is the passenger side drain hole, it is immediately above the selector switch of the auto transmission, above it and on the side of the transmission tunnel.
Hope this helps people.
| Search AULRO.com ONLY! |
Search All the Web! |
