Well I traced things back a bit more and found some sort of distribution block/valve behind the driver's side wheel arch.
I have air at this block on 2 black lines, but nothing on the 2 yellow lines. See picture for which ones. I undid the brass nipples and both black lines seeped air after undoing then about 1 turn (did them straight back up again) but the yellow ones undid completely with no air released.
Does this look like the block is faulty? That'd be cheaper (by the looks) then replacing the strut!!
I can blow air through the line marked "Front Driver's side line" and it come out where I disconnected the strut, so no blockage in that line at all.
