Results 1 to 10 of 23
Thread: D2 - air in the brake lines?
    Feb 2011
    Hobart, Tasmania, Australia
    Question D2 - air in the brake lines?
    About 12 months ago I removed the factory rubber brake lines and replaced with Terrafirma stainless steel braided lines that are +2" longer. Manually bled the system and all has been fine.
    Until a month ago when I drove into a gate. The brakes failed on me, I was pushing and pushing the pedal but the brakes just wouldn't bite and the car just didn't slow down (until it hit). They worked again afterwards, so I accepted that it was my poor judgment and driver error.
    Yesterday, however, I was moving the D2a out of the drive way and it happened again (this time I was traveling much slower so nothing was hit thank fully)!
    This morning I've had the wheels off and went around bleeding the brakes. They were fine until I got to the last one, the drivers side front. It was full of air (the cause of my lack of brakes)! 500ml of fluid later, bleeding with both the engine off and then on, it's not pushing out fluid with no air in it.
    I'm going to leave it to sit for a while and then I will bleed it again to confirm.
    Is there something else I need to do on the D2 because of the ABS or TC?
    I have checked the whole system and can't find any evidence of leaks. The brake fluid level has not gone down since I last bled them about 12 months ago.
    Ideas?
    I might be wrong, but I just had a feeling that you couldn't bleed D2 brakes yourself because of the ABS modulator, you had to have it professionally done. I am guessing it has to have so sort of positive pressure to bleed brakes.
    Feb 2011
    Quote Originally Posted by walker View Post
    From what I understand, you require Testbook to do it if you have replaced the ABS module or anything up the line from the ABS module. But down the line items such as brake hoses should be fine to manual bleed.
    Rave outlines the manual bleeding procedure.
    May 2003
    On The Road
    Some say you need a nanocom to bleed them,
    some say you can do it by tricking the ABS to operate, the so called powerbleed.
    I have had two dead pedals, in two different D2's, both in exactly the same spot doing exactly the same thing. Start from cold, select gear, idle off to first T intersection. I put it down to lack of vacuum, so now I drive off and to hell with the neighbours.
    May 2009
    Perth Western Australia
    Having this exact problem atm and have not been able to push fluid out the front lines, it is in at Lifestyle 4wd atm and it has had all checked or replaced you may want to call Steve Armour as he has been going over and over the problem discussing it with other mechanics in Perth to try and come up with a remedy..(08) 9271 7900
    Feb 2011
    Brunswick, Victoria
    The relay trick just runs the return pump which is effectively what a power bleed does. This won't address problems cause by air trapped in the modulator valving.
    There is a full bleed procedure in the WABCO support documentation that can be roughly adapted to the Nanocom/Hawkeye.
    I made a start sometime ago on Nanocomising the procedure.I haven't tested the process so feedback is welcome. I'm working on the theory that Land Rover would have followed WABCO tech advice on bleeding.
    Paul
    Brake Bleeding Procedure
    The following brake bleeding methods explain
    how to bleed a hydraulic ABS dry
    modulator assembly during installation, or in the
    event of air in the brake system. These instructions
    are for manual bleeding with electronic diagnostic tool
    and include the procedure for bleeding
    both the master cylinder and the brake system. In
    some cases, for example if you are replacing only
    the modulator assembly, it may not be necessary
    to bleed the master cylinder.
    Manual Bleed Procedure with Electronic
    Diagnostic Tools
    NOTE: The electronic diagnostic tool must be
    capable of actuating (energizing) the outlet
    solenoid valves for each wheel for approximately
    10 seconds and activating the pump of the
    modulator. The inlet solenoid valve should be
    open (de-energized). Both Nanocom and Hawkeye
    diagnostic tools can be used to do this.
    1. Apply the parking brake and chock the tires.
    Turn the ignition OFF.
    NOTE: The ignition must remain off for the
    initial bleed procedure; energizing the unit
    during bleeding must be impossible.
    2. Perform brake bleed procedure for wet
    module, bleeding the circuit and master
    cylinder if required prior to connecting
    diagnostic equipment.
    3. Connect diagnostic equipment to OBDII port.
    4. Turn ignition switch ON
    5. Push on brake pedal with maximum force (firm
    pedal) and hold.
    6. Activate the Modulator Bleed function on the diagnostic tool
    starting with Passenger Front. (Note: you may be able to use the "test" function for each wheel for this step)
    7. Release brake pedal for 5 seconds and run the Power Bleed function
    for approximately 5 seconds.
    8. Repeat Steps 5 through 7 three additional
    times.
    9. Perform manual bleed on appropriate wheels.
    NOTE: To perform a manual bleed, follow
    Steps 2 through 8 under “Manual Bleed
    Procedure (Wet Modulator Assembly)”
    10. Repeat Steps 5 through 9 for the remaining 3
    brake actuators, working in order of Drivers Front, Passenger Rear, Drivers Rear.
    NOTE: If a firm brake pedal resistance is felt and
    the brake pedal pushes back when the solenoids
    and pump are simultaneously actuated for each
    brake circuit, the system bleed procedure is
    complete. If there is no firm pedal resistance,
    repeat the bleed procedure and/or look into brake
    system defect, (leaks, etc.).
    Wet Modulator Assembly Bleed
      Turn the ignition OFF and disconnect the
      battery terminals.
      entire bleed procedure; energizing the unit
    2. Fill the reservoir with DOT-approved hydraulic
      brake fluid.
    3. Depress the brake pedal five times using the
      stroke between 1/3 travel and maximum travel
      in 5 seconds.
    4. Release the pedal for 5 to 10 seconds. Air
      bubbles will rise into the reservoir while
      depressing and releasing pedal.
    5. Repeat Steps 3 and 4 another three times, or
      until sufficient pedal resistance is felt.
      WARNING
      Do not let the brake master cylinder fluid get
      below the minimum level during the bleeding
      operation. Keep the master cylinder reservoir
      filled with new DOT-approved brake fluid as
      specified by the original equipment manufacturer.
      Failure to keep the brake reservoir level above
      minimum could result in more air entering
      system, making it impossible to effectively bleed
      the system.
    6. Bleed the brake system. Put a wrench on the
      brake actuator bleeder fitting. Start with the
      Passenger Front, then attach a length of clear plastic
      tubing to the bleeder fitting. Make sure the
      tube fits snugly.
    7. Submerge the tubing in a container of clean
      brake fluid.
      NOTE: Both the tubing and container must be
      able to withstand to the effects of brake fluid.
    8. Depress the brake pedal 10 to 15 times, using
      the maximum available stroke.
    9. Loosen the bleeder fitting until the fluid begins
      to flow, (about 3/4 turn), while depressing the
      brake pedal through its maximum available
      stroke.
    10. Tighten the fitting firmly prior to releasing the
      brake pedal.
    11. Repeat Steps 6 through 8 several times until
      the discharged fluid is free of air bubbles.
    12. Repeat Steps 3 through 9 to bleed the
      remaining three brake actuators. Bleed in
      sequence Passenger Front, Driver Front, Passenger Rear, Driver Rear.
    13. Check the travel of the brake pedal. If a firm
      resistance is felt the manual bleeding
      procedure is complete.
    14. Check the fluid level in reservoir and fill if
      required. Replace reservoir cap and dispose of
      used brake fluid.
    15. Remove wheel chocks.
    Feb 2011
    Nanocom Evolution has the following under SLABS / UTILITY / ABS BLEEDING - TESTS:
    • POWER BLEED
    • MODULATOR BLEED
    • FRONT RIGHT TEST
    • FRONT LEFT TEST
    • REAR RIGHT TEST
    • REAR LEFT TEST
    Struggling to find any instructions on their usage though.
    EDIT: found the following:
    Power Bleed.
    This function allows to perform bleeding of the main circuit. It activates the pump for a few seconds and you must repeat the function until the oil reaches the brake. The same work can be done by pushing the brake pedal.
    Modulator Bleed
    Modulator bleed must be preformed with pipes closed, pushing the pedal with maximum strength during the function. Once function is preformed, release the pedal and repeat until the pedal stroke is normal.
    So seems like Power Bleed is used on an empty system to get the fluid going through. I assume the pedal doesn't need to be pressed.
    Modulator Bleed requires the pedal to be pressed.
    But unsure on the tests. Do they need the pedal to be pressed?
    EDIT AGAIN:
    FRONT RIGHT TEST - FRONT LEFT TEST - REAR RIGHT TEST - REAR LEFT TEST
    This function activates the modulation of the brake on the desired wheel. During the function if you turn the wheel by hand, you can see that it is blocked several times for few seconds.
    http://cdbl.free.fr/Nanocom/V1-V2/Ma...iscoveryII.pdf
    Feb 2011
    Brunswick, Victoria
    Quote Originally Posted by twr7cx View Post
    The procedure I posted above is pretty close to what Testbook steps you through as far as I can tell. The best information I'd found was a really sketchy description by a guy who had helped a mechanic do the testbook routine. The WABCO bleed docs seem to match up in general long windedness and the need for repeated bleeding.
    The basic approach of modulator bleed with pedal depressed, pedal up for 5 seconds, power bleed, then repeat 3 times will force any air in the system to the calipers. Followed by a manual bleed it should work well enough.
    Paul
    Feb 2011
    I have discovered something strange. There seems to be an almost continuous leak of air through the right front (drivers side) caliper bleed nipple. With the nipple shut and a hose attached full of fluid, are bubble continue to come through (no fluid does though).
    I checked the hose fitting and it's tight. Tried it on the other three calipers and they don't do it.
    So I removed the bleed nipple and cleaned the seat in the caliper. Refitted and same deal.
    Removed a bleed nipple from a 1994 Ford EF Falcon GLi station wagon and fitted this and that stopped the leak.
    No air is coming out when bleeding any of the four wheels. Have run the power bleed, modulator bleed and tests using Nanocom Evolution numerous times as per the instructions above.
    Strange.
    Feb 2011
    Arn't you vehicles petrol V8's? If so, they should have vacum at idle, so reving the engine up (which I assume is what you mean by:
    ) won't create any more vacum. The wider you open the throttle, the less vacum there would be...
