Also - if anyone knows of a better one, could you please post up the link.
Ta
If any of you have tried to work out what position and what strength gas strut to use when custom building things, you soon realise it is not straightforward!
I have been doing scale drawings & etc to plan them out, and taking 4 or 5 goes to get it sorted.
Then I found this page:
Gasveren berekenen.
It is Dutch, but Google will translate it for you.
Enter your proposed dimensions on the 2nd tab, and it will animate the opening angles you will achieve. e.g. if you put the strut attachments too close together, then it shows that the door will not close.
The animation could be better (and maybe slower) but it saved me some head scratching, so maybe someone else will find it useful.
David
Ta
I had thought about putting gas struts on Grumbles hood.
I had the same thoughts as you Spudboy , no idea where to locate or what sizes etc.
I await with anticip.p.p.p.ation
Can someone tell me how to get google to translate? I have never done this before.
Dave.
I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
1983 RR gone (wish I kept it)
1996 TDI ES.
2003 TD5 HSE
1987 Isuzu County
Go to http://translate.google.com/ then in the left hand box put the web address in that you want translated. I leave it as 'Auto detect' and set the translate to to 'English'
Which should give you
Google Translate
I will be getting this thread stored,probably "the good oil" .
VERY HANDY link
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
Moved to Technical as this isn't a General Chat topic. We don't want it lost in General.
Thanks for that, that'll be handy with the swing away tie carrier design.
Sent from my GT-I9305T using AULRO mobile app
Cheers, have done some time consuming trial and error setup a before.
| Search AULRO.com ONLY! |
    Search All the Web! |
