Maybe, it sits at 400mm off the ground, main chassis rails are at 350mm and the rock sliders are at 500mm, so a bit lower than the side but still above the chassis rails. It would have to be a big rock directly behind the line of the front wheel so maybe at that point I should stop and go around
Heading bush for 8 days via Coolgardie, Norseman and Lake Ballard in the West, so will see if it is still OK when I get back.
