Page 4 of 11 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 107
Thread: New addition to the garage
  1. #31
    Jan 2013
    Sydney, NSW
    Two hot days, today and yesterday, and both days the temperature gauge did things I don't like. Looks like it'll be going to get looked at shortly.
    If it can't drive without getting hot, it certainly can't tow.
    --Striker.
  2. #32
    Jul 2014
    Striker, I am assuming that getting it looked is under some warranty....if not and you need to pay be careful someone doesn't throw a lot of parts at it as it could be one of many!
    2000 4.6 HSE Alveston red
    2007 307 xse peugeot
    1974 xj6l jaguar
  3. #33
    Jul 2014
    Many possibilities that is
    1974 xj6l jaguar
  4. #34
    Feb 2013
    Gosford, NSW, Australia
    Mate
    Is that from the dash temperature gauge or the engine watchdog thing?
    Steve
  5. #35
    Jan 2013
    Sydney, NSW
    Quote Originally Posted by TheTree View Post
    Mate
    Steve
    Dash gauge. The EMS (Engine Monitoring System) hasn't been installed yet.
    I need the temperature sensor installed ASAP, but everyone tells me it's a bit complicated, and they're not interested.
    --Striker.
  6. #36
    Feb 2013
    Mate
    It sounds as if you need to ask Davis Landies about the temp, surely they have checked the cooling system etc before they sold it to you.
    Hard to believe no-one wants to install a temp monitor for you, oh wait this is Australia in the 21st century
    Steve
  7. #37
    Jan 2013
    Sydney, NSW
    Mate
    Steve
    The car is now back at Davis Performance Landys.
    The job list is:
    1. Wire thermos to come on when aircon is on.
    2. Install aux water temp sensor (for use by EMS).
    3. Check radiator for blockages.
    4. Fix corrosion issue on existing temp sensor and attached plug/wiring.
    I'm surprised that in a car as recent as a P38, the thermos don't already come on automatically when the aircon is turned on, but between making sure that happens, and checking the radiator for blockages, I'm hoping the issue is resolved.
    Once the aux temperature sensor is fitted, I can start on the EMS, and I'll have a much better idea of the real water temperature.
    --Striker.
  8. #38
    Douglas Park, NSW
    Quote Originally Posted by Striker View Post
    I think you'll find they come on when the temperature and/or A/C gas pressure gets high.
    IIRC, they can also vary in speed.
    Scott
  9. #39
    Feb 2013
    They do indeed come on when needed, see attached page from RAVE
    Steve
  10. #40
    Jan 2013
    Sydney, NSW
    Quote Originally Posted by Scouse View Post
    That is indeed what Bruce said also. He mentioned that working this way means the coolant already has a chance to get hotter before the cooling kicks in, and wiring the fans directly to AC-on would help with the issue.
    I figure if the car gets hot on a 35 degree day, imagine what would happen on a 45 degree day with a 2.5 tonne trailer on the back.
    --Striker.
