Results 1 to 10 of 10
Thread: Rear Tyre pressure 130
    Nov 2006
    Alice Springs, Australia
    The manual says around 65 psi in the rear tyres of a 130 is this fair dinkum??? what do you guys run? i have cooper 235/85 on the fender and i reckon if i run this tyre pressure i would just rip the lugs off the tyres if i forgot to let them down off road. I know that can be fixed by not forgetting to let them down, but struth! 65 psi? is that normal operating pressure that people use?
    Cheers from the Desert
    Rexy
    2000 130 TD5
    Oil in the Harness, suspension knock, transmission clunk, engine oil leaks, exhaust manifold leaks, centrifugal oil filter stripped bolts, a/c leaks, door leaks, wouldn't trade it for the world
    Ballajura, Perth, WA
    trye pressue how long a piece of string
    buts the recommended tyre pressure for the original tyre fittment by manufacturer.
    you should use recommended trye pressure for your trye
    bearing in mind load carried speed travelled and terrain being covered will see variaions in pressure actually used
    I run the Range Rover & the Defender (110) at 50psi. Tyres last very well. 65psi sounds right if you've got the 1,500kg payload. But talk to people who run Coopers, because they may delaminate at that pressure .
    Wilbur Guest
    Gidday, I have been wondering that myself.
    I am one of those slack dick-heads who checks tyres by glancing down to see if the rim is touching the bitumen - every 6 months or so!
    After getting the new toy feeling after buying a good air compressor, all the tyres were set up as manual - including 65 at the rear.
    What an amusing ride quality it had unladen......not so bad on BIG bumps, but on light corrugations, quite a revelation. Thought the bugger would split in half.
    With my 500kg camper on the back, it is great at 65 PSI.
    Unladen, I now run 45 front and rear. That probably means my insurance is void, I will be arrested and sent to jail, my license will be revoked and all sorts of nasty things, but at least the poor old Defender will be happy!
    Cheers all,
    Paul
    Island
    you're talking general running around unladen? 65psi would be max pressure at max load.
    try this rough guide. check your pressures cold then check them again hot, aim for a pressure change of around 2-4psi, if less than this lower the initial cold pressure, if more then increase the initial cold pressure.
    Melbourn(ish)
    65 psi is for the stock 7.50 r16s or thereabouts...
    yes its right....
    its to do with contact patch vs the weight you put on it... If your patient you can work out your own tyres optimum inflation pressures...
    heres how..
    jack up the vehcile wet the concrete, lower the vehcile so the full weight is on the tyre...
    jack up the car and turn the wheel 180 degrees... look at and measure the wet patch...
    its area(in inches)*psi should equal half the weight on the axle..
    goto somewhere like beaurepairs and somewhere they will have the poster that shows the differences in contact patches at different pressures, for cars...
    so long as your contact patch looks like the one in the middle that says "ideal inflation" your laughing, remeber the size/shape of that from your vehicle.. (yours will be bigger as you have a bigger tyre)
    when you add weight you just add pressure untill the math tells you that your contact patch is back to the right size.
    an easy meausre once you have it figured out is 2 pieces of wire bent at 90 degrees.. slide them into the tyre on the ground like a pair of calipers and tape them together. then when you change the load slide the caliper back into position, if it wont go, add air, if it goes really easy let air out.
    Dave
    Fozzy, 2.25D SIII Ex DCA Ute
    Yass NSW
    I have been running mine at 50psi all round for on road use. I have 285 75 R16 BFG Muds.
    Free Again Thanks Dan
    I run 7.50/16" steeltreks on my defender wagon and ive been running 36 psi in the front and forty in the back
    but im about to change the pressure ,s im going to increase the pressure
    i was thinking 45 psi front and 50 psi in the rear
    as others have said i would trial different pressure,s untill you have something that you are happy with
    on another note i did a advanced driving course and i was told bump your tyre pressure,s up and your car will handle better and your tyres will last longer
    my 2 bob
    I've been running at 36psi all round, works for me.
    Also heard that running at higher pressure puts more stress onto the suspension, chassis, vehicle - bumps and the rest usually absorbed by tyres at lower pressure gets sent straight to the vehicle.
    Simon
    Smile
    I run 40psi in my BFG AT's all round on my 95 130 crewcab when it empty and progressively up the pressure as I put more weight in it. 65psi is just within the pain barrier on the road but is very painful on the gravel and can make the rear end a bit loose (no pun intended).
