24th May 2010, 06:20 PM
Conquest Knight XV- Pretty striking vehicle
Conquest Vehicles | Knight XV
Looks impressive in that Darth Vader way.
Armoured too!
24th May 2010, 06:32 PM
I want one
24th May 2010, 06:40 PM
I am sure Colombian drug lords, African despots, Middle east oil barons, and hollywood celebrities are lining up to purchase them as we speak.
24th May 2010, 06:45 PM
#4
Originally Posted by
adonuff
I want one
YEP me to i can see myself driving round the town in it...
24th May 2010, 07:30 PM
#5
Yep
Like when I first saw it. but the I could be happy with a H1
24th May 2010, 07:41 PM
#6
I'm in....
How many do we need to get a group discount?
25th May 2010, 07:16 AM
#7
I couldn't believe the size of it compared to the Hummer!
25th May 2010, 10:08 AM
#8
This thing is friggin huge!
Length240"(6096 mm)Width92"(2337 mm)Ground clearance14"(355 mm)Height100"(2540 mm)The vehicle is built on a super duty specially modified F550 Ford chassis platform (making parts and service easily accessible globally).
Engine: Ford, V10, 6.8-litre gas engine with E-85 Ethanol Conversion system added, (referring to as Flex Fuel engine) Flexible fuel vehicles (FFVs) are designed to run on gasoline or a blend of up to 85% ethanol (E85). Diesel engine also available as an option.
Horsepower: 400 HP and 500 ft lbs. torque (approximately)
4 X 4: Electronic, push button 4WD
Transmission: 5- speed Torqshift automatic transmission
Brakes: Four-wheel disc anti-lock traction control
Wheelbase:141"(3576 mm)GVWR:17,950lbs(8,159.09 kg)Armored Curb Weight: The finished vehicle weight is approximately 12,000 lbs. (5,454.55 kg)
Fuel tank: 40 gallons (US) (151Litres)
Air conditioning: Factory Air conditioning in-cabin
Tires: Four LT40X13.50R20 Mickey Thompson Baja Radial ATZ with ballistic run flats
Vehicle armor: The KNIGHT XV’s armouring level varies based each client’s specific requirements
25th May 2010, 10:23 AM
#9
well with a 400hp engine, 8.1 ton in weight and 151litres of fuel... wow..
its gonna be a high performance distance monster!... not..
should be able to just crawl slowly between fuel stops...
Steve
