Fitted the grille to my own 90 looks awesome if i may say so, much more robust than the factory.
We are working on some very interesting perforated S/S grilles, as soon as they are done ill post them.
David
Im looking for a local member that would fit this all alloy grille to their currant model Defender.
The grille will not cost the member any money, as long as i'm able to use the vehicle for promotion shots.
Please PM if you can help.
David
David
An image of said grille, i have designed a pair for around the head lights they will be made in time.
David
Then add a flyscreen/bug catcher for the radiator and you're all done!!
MY16 D4 TDV6 - with a little Cambo magic for towing "The Brick"
MY95 RRC LSE Vogue Softdash "Bessie" (turning circle comparable to QE II) with MY99 TD5 and 4HP24 transplants. Back home Nov 22 after a magic overhaul by Chivalry
SADLY SOLD MY04 D2a TD5 auto Classic and MY10 D4 2.7 both with lots of goodies
does the car your after need to be 'bare' on the front. as I have the factory A Frame, led light bar, and slightly bent front bar :S but it is a 2012 Puma. .
Leroy
Grille is now fitted to my 2012 Puma 90, still working on the matching side grilles.
Has anything happened lately with this project it looks the goods
Cheers Paul
Ate you going to make some for older defenders as well? TDi?
gone
1993 Defender 110 ute "Doris"
1996 Discovery 1
current
The grill on my 90 will be up for grabs real soon, i'm working on a couple of new better designs
Watch this space!
I'm really surprised no one has had a crack at a nice looking slat like grill yet that moves and can be closed down for wading like a snow blind type thing..
bit like the venician blinds on your windows but obvisouly without the cord!!
The defenders current grill is a very slat like version
Now if anyone builds one I want a kick back
Search AULRO.com ONLY! |
