At a guess, you have a wiring fault, or break in the CANBUS ring.
You'd need to get a fault reader on it to start with.
Hi there,
In the last couple of weeks each time i start my 2009 SE D3 the trip computer and odometer will automatically reset. I was wondering if anyone has had similar issues and knows what may be causing this?
Also sometimes a warning will appear on start up saying my park brake has a fault and auto release is not available. would this be related?
Is the trip computer set on auto? This will reset each time the ignition is switched on. D4 has this feature
hmmm no auto setting so will have to get deeper. I was looking at a faultmate reader a while ago, wishing i had have got it now.
Cheers for the reply, will let you know when i suss it out
You'll find a Faultmate, or similar, a very worthwhile investment.
Any ideas where I could purchase a faultmate msv-2 extreme with two vehicle capability? Seems the company i was looking at some time ago no longer is around. Is it best to just order it from BBS?
Could be your battery is running down.
I had the trip meter reset every start just before the battery went U.S.
So maybe have that checked.
Jonesfam
Well after all that, it was the battery was on its way out. Nice easy fix and an even better excuse to convince the missus I needed a diagnostic tool
Cheers for your help guys!
Search AULRO.com ONLY! |
