Is the fluid foaming, discoloured or low?
I wound first check the hoses to and from the pump for leaks and ensure the connections are secure, then replace the fluid if all looks ok
I use penrite PAS fluid and replace progressively by emptying then refilling the reservoir, run for a bit then repeat until the fluid is clear/ clean.
Simon
