Oh good!
Hi All!
Been a while but it's back to the font of all knowledge- AULRO!
Anyone had issues with new plenum covers, the plastic trim that goes under the windscreen (wipers come up through it)?
I replaced my cracked one last year with a new genuine one. Within a few months it warped like crazy along the top edge. Rovacraft were good and replaced it no issues. But within a month the new one has also 'chucked a wobbly'!
Rovacraft contacted LR Aus, who replied they had only had one complaint and rejected it as 'during install, the A pillar covers had not been removed and replaced, hence the plenum cover was squashed inwards and warped' ???!! Baloney, I thought, and checked mine. 1-5 mm gaps at both ends in true LR fashion. It doesn't in any way touch the A pillar trim. Made a video showing the clearance and Rovacraft contacted LR Aus, who have now said 'oh well we'll send a new one!'.
But why is it warping? It's not that hot here (SW WA). The new cover does look a slightly different plastic to the old (more waxy and matt than the original).
The warping seems to occur between the two wiper spigots (visible mostly along the top rubber seal edge against - or not! - the windscreen). It's almost as if in heat it is trying to expand lengthwise and the wiper spigots stop it, so it warps. But the original never did this (it just cracked in half!).
And ideas or experiences?
1974 Military Lightweight Landy --- Some dementia at 48 years old
2000 Disco series 2 now sadly moved on!
No5 Trailer joined the fold... Awaiting graduation to road licensed!
Ford Ranger 2013 XLT.
Oh good!
I had the same issue with a new one I bought about 12 months ago. Massive warping along the top after only a couple of weeks.
Led Richmond replaced it for me. I think the new one has some minor warping now. I'll check it tomorrow.
Sent from my Nexus 5 using AULRO mobile app
2003 D2a TD5 Auto
1960 Series 2 Petrol
Ok so I will sika the middle crack in my original unwarped one...
Cheets
I recently replaced mine with a second hand piece, after a couple of months it cracked straight through the middle. I have a feeling that the mechanic may have fitted it without taking the bonnet off which inturn you need to bend it upwards to get it on. I think I notice a hairline crack afetrwards which then grew.
How much was the new one you bought?
Did you fit it yourself?
bronson
my new one has been on for about 4 months,so has gone through the buildup here in Darwin as well as a few 40+ days at tennant creek,still as straight,Bought from TRS perhaps they use a different supplier,Just wondering given the comments about the wiper hole interfering are the left hand drive wipers in a different position.if so perhaps perhaps the plenum is different.
Darwin
03 disco 2a td5
93 tdi disco [gone to a better home]
2003 d2a v8 retired hurt
1988 k100rs bmw gone
85 county izuzu [gone to a better home]
69 series 2a [gone to a better home]
series 2a [gunnado]
series 3 [gunnado]
and the tinny
Hi Lewy,
They are universal - there are blanking plugs in the Left hand drive wiper holes.
The holes in mine are in the right place, not interfering, just it seems that the warping is 'between' them - as if when the wiper spigot nuts are re-fitted, they clamp on the plastic and stop length-wise expansion?
Think it was over $300 but it was a year ago now...
Hi Singlecell,
What were the results of your warping analysis?
Search AULRO.com ONLY! |
