Do you mean you replaced the original MSB101193 ECU with the NNN500030 and it doesnt start with it or it worked with it before and it suddenly doesnt start?
also what do you mean "not start"? , no crank or crank but no fire?
I have discovery 2 2000 td5 with ecu nnn500030 not start. i try to make test with x431 but can conect the ecu when i try to read or test the engine.
any way to test and find the problem??
thanks
Hi . the ecu is original. the car was 3 month stoped when try to start it not start any more. it crank but no fire. try to make a diagnostic with x431 i can read the eka but cant read test the engine because it fail read ( give me time out). and the check engine light not show.
thanks
Try cleaning pins and sockets for BCU and ECU modules and plugs with contact cleaner.
My D2 had been sitting for a while and doing this got it running again.
James
measure the voltage on the battery while cranking...if it fails under 10V it will hardly start...maybe you just need a strong battery
cos the Td5 is not OBDII compliant
nanocom, hawkeye, lynx, autologic, testbook t4, rovacom, dec superscan, tribox mobile.... and maybe few more just to have dedicated menu for D2
Search AULRO.com ONLY! |
