I paid about $1700 two years ago for a 4.5 metre door and electric motor, that included fiiting too.
Has been okay with no problems
Ok, finally got a house with a garage but it has the doors that slide sideway and they overlap. So even thought the garage is 6 metres wide I have trouble just fitting the disco into it.
I want to remove these doors and replace them with a single 4-4.5 metre wide roller door so that I can reverse the disco (or the project rangie when I get it) right into the middle of the space and have room either side of the car to work on it. At the moment I can reallon only park in either bay cause of how the doors slide open.
So I am thinking of doing some 1 metre returns at the front and putting in a roller door. So my question is, what am I up for for a roller door?
Angus
what height are you chasing for clearance (dont forget the lifted rangie) and what hieght and roof pitch is you shed ?
Paul
PaulT
REMLR 256 / SLOw 4 (P)
W/Shops/trailers & GS's
RRs, Disco's, 110s & 109s.
I dropped a clanger when I built my garage and shed, I made all openings 2.4 metres high
The landrover has about 50mm to spare with roofrack on, next time I'll get it right
Just for info, a domestic rollerdoor needs about 300-350 mm of real-estate when fully up. Not much can be done on the side (gutter) walls to gain height, but if the door is going in the centre of the gable (pointy bit) end, you can push it up a bit for more clearance.
Paul
PaulT
Saw a side roller door at the home show a few years ago.
You didn't loose the 450mm that the roller door needed so gave more head room.
Rolled behind either side return with elec. motor.
Don't know if they are still around, but just an option given you have sliding doors now.
Cheers.
Slunnie
The shed I built had 2.5m openings (x2).
I was originally going to install sliding doors, but in the end I thought roller would be easier. However the prices were $$$. So I bought 2x second hand doors from a demolition place for ~$100 each. I needed to buy locks and tracking for 1 door. About another ~$100.
One door was even the right colour, but I resprayed them both with colorbond spray cans. About 3 cans per door @$15 each.
Search AULRO.com ONLY! |
