Results 1 to 10 of 21
Thread: No turning lights in D4 bi-xenons
    NSW SW Slopes
    I've discovered that there are no static turning lights in the bi-xenons in my D4 SE contrary to the Oz specs. There is only a plastic silver dome where the bulb is supposed to be.
    Does anyone else have the globes or have they been omitted from all Oz D4 bi-xenon lights?
    Do you mean turn indicators (blinkers/flashers)?
    Melbourne, mostly
    Do you mean adaptive lights? Not all xenons are adaptive.
    NSW SW Slopes
    Sorry, they are called cornerning lights. They are lit when the blinker is on and perhaps some other conditions such as only up to a specific speed. They are used to see right or left as appropriate when about to turn into a driveway etc and can be useful in the bush. They are located within the headlight assembly and below the blinker.
    They are not related to adaptive headlights that follow the direction of travel.
    Nedlands, WA
    Graeme, if it's the same as the D3 as far as I'm aware, the static cornering lights are only available with the 'bright package' and/or active headlights
    NSW SW Slopes
    Specs says std for D4 SE. SE has bi-xenons, puddle lights, footwell lights and fog lights which IIRC made-up the D3 bright pack.
    In the D3, the cornering lights are only available with the adaptive bi-xenon headlights, not the std bi-xenons. It requires the adaptive xenon loom, which is one of the headaches involved in upgrading the bi-xenons to an adaptive set.
    So is the D4 fitted with the adaptive loom?
    Gordon
    NSW SW Slopes
    I have no way of knowing if the adaptive loom is fitted or not, although there seems to be a lot more wires than necessary.
    The latest 4x4 Australia D3/D4 comparison article also lists the cornering lights as standard for the SE. The report says My Disco 3 SE came with optional bi-xenon lights, but they're now standard on the SE and they incorporate cornering beams. The new beams were noticeably broader than the Disco 3's, even when driving straight ahead. The author must be referring to the cornering beams due to the final phrase.
    Is it possible that the halogen high beam alignment issue with a few vehicles (incl mine) is related and that the headlight assemblies are for another market that requires excessively low-set dipped beams and that market also misses out on the cornering lamps?
    Cornering lights were only available with the adaptive units.
    Again as the D3 was launched the info in the brochure was incorrect.
    Having just read the brochure again i can see what you are saying Graeme.
    But i think again the D4 will be without the cornering lights unless you get the adaptive units which incorporate this globe/wiring & a different harness to it.
    HTH.
    NSW SW Slopes
    There is a possibility that the writer has mistakingly thought the SE has cornering lights even though he states that the bi-xenons with corning lights are standard with the 3.0 engine as he also states that the 2 D4s tested were both SEs yet one had the 5.0 engine. The pictures of headlights in the article are not particularly conclusive but when compared with mine from the same angle, my plastic silver bubble is clearly visible and it is not in the pictures.
    I'd like to know if any other D4 owners with the non-adaptive bi-xenons have globes in the cornering lamps? They are easy to see.
