Thread: Swapping a 130 tub for a tray
    Scarborough, QLD
    Anyone know how much a drop-side tray would cost for a dual-cab Defender?
    Thinking about buying one to put a slide-on camper on, and trying to scope out costs.
    May 2008
    Only in your mind now
    Ring Brad at East Coast Commercials Acacia Ridge. Unsure what he may have left as I got mine a few weeks ago from there. Will have to get over there to pick up once work slows down.
    austastar's Avatar
    Jul 2009
    Hobart
    Hi,
    Not sure of Qld regulations, but I doubt you can legally extend the tray more than 60% of the length of the wheel base, past the rear axle.
    That may make it a bit short for a camper on a dual cab 110 unless you are putting the bed up over the vehicle roof.
    Jul 2008
    Lismore NSW
    Check out the wreckers for 2nd hand one- my triple m aluminium tray just bolts together -so you can easily modify size to suit or replace damaged sections. Not as strong as a steel one thou but I often carry tonne + loads(light wieght tray an advantage for GVM)
    Head boards a bit weak.
    Brett
    110 300tdi c/chassis
    109 h/top
    Logan Village area S.E. QLD
    as has been said ring Brad at East Coast that is where we got our tray a few years ago it was ex fisheries and cost $300.00 with a set of brand new Land Rover mud flaps thrown in
    Mrs hh
    Series Landy Rescue
    Our FB Page..
