Thread: Installing a towbar on P38 - pics and info
    Jan 2008
    Medowie, Port Stephens and Sydney
    Probably one of the easier jobs i've done on the beast but i took my time on it with a lot of fiddling around. I'd guess if i had to i could install in 45 tops.
    Hope this helps anyone that wants to have a go. Not the best user guide below but better than nothing.
    Summary;
    1. 2nd hand hayman reese bought on ebay
    2. Parked on a down facing slope in driveway to lift the rear and make access easy
    3. Removed rear bumper
    4. Cleaned bumper with truck wash
    5. Sprayed rear bumper with 3M black bumper spray
    6. Cleaned tow bar with wirebrush and truck wash
    7. Sprayed tow bar with black paint
    8. Parked car on flat section of driveway (nuts and sockets kept rolling away
    9. Installed tow bar using high tensile bolts
    10. Reinstalled bumper
    11. Grinned smugly at a job well done
    So, mid fitting after moving the car on the flat section of the driveway, the wind picks up and drops a huge branch right where i was parked! See the pic below
    Great timing
    Pics below;
    2nd Hand tow bar
    Removing bolts - (embarrassingly, i searched for a long time looking for a socket with a star shaped fitting...)
    Undo the clips...
    1 x screw to be removed on both sides
    Pull the bumper off - easy.
    A huge amount of collected dirt and a bent bumper...
    took a while to straighten this out..
    Hanging the bumper in the shed made spraying a lot easier
    Good timing to move the car 1/2 hour before this crashed down - this would have really hurt!
    Was tempting to drive around like this for a while to scare the neighbours
    Scratched my head on 2 long or four short for a while...
    Bolt action
    Will have to post the final product tomorrow - just realised i don't have it!
    Good luck attempting this - easy job, hope the pics help anyone jumping onto it.
    David
    Douglas Park, NSW
    Nice work David.
    How'd you straighten the plastic bar cover? I glued aluminium angle to the underside of mine.
    Jan 2008
    Nice work David.
    Do you mean you glued the plastic bumper to the metal section?
    My issue was the metal being bent and pushing the plastic up. With some technical precision belting with a hammer, i've managed to get it back a little closer to normal. Still needs a bit more thought.
    Douglas Park, NSW
    I can see where you straightened your metal section now.
    My plastic cover was warped (like 99% of P38s). I glued the angle piece along the underside rear edge of the plastic cover.
    richard4u2 Guest
    in the top photo where does that flat peice at the end of the square channel bolt onto
    Quote Originally Posted by richard4u2 View Post
    The cross-member under the wheel well.
    Jan 2008
    I haven't actually bolted that part on yet. None of the bolts i bought would fit but not to worry, not towing anything yet and can add these bolts without removing anything, bumper etc.
    The bolts will need to about 70mm to 15mm long from memory..
