Thread: HELP NEEDED ( SPEEDO NOT WORKING )
    May 2008
    Sunday I disconnected my battery to move it as to set it up for next weekend to install a dual battery system and connected it back together , but i notice this morning going to work that my speedo was not working and not counting km traveled (speedo still has amount of kms traveled to date 86000km) ,also i notice my cruise control is not working?
    every thing else seems to be OK ecu goes thru its test when you start the Defender so i am wondering has anybody come across this problem before i have not got a nancom to see does a fault have to be corrected has anybody got an idea what it could be.
    Declan
    VladTepes's Avatar
    Bracken Ridge, Qld
    Obviously not a Tdi... do you have a TD5 or Puma? (Might help people answer the Q a bit easier)
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    May 2008
    Sorry should have said its a 2006 110 TD5 i have checked all fuses that is why i think it might be a ecu problem.
    Declan
    May 2008
    Just wondering is there anybody in the Adelaide hills with a nanocom to have a look at my defender to see what faults are showing for the speedo not working.
    Thanks Declan
    May 2008
    Found the problem on this thread No Speedo or odometer in TD5 Defender thanks for your replies.
    Declan
