Results 1 to 10 of 18
Thread: Hi-Lift jack vs exhaust jack vs hand winch
    Outer Sydney
    G'day everyone!
    I would like to get myself some inexpensive recovery equipment for self recoveries. So what do people believe is the best piece of recovery equipment out of the following? A hi-lift jack, exhaust jack or hand winch?
    Thank you!
    Edward
    Oh and i drive a 110 County.
    Nov 2006
    cardiff ,NEWCASTLE.
    Hi lift jack ,can be used as a winch aswell albeit slow but it does work...
    So many uses for a hi lift.
    1969 LWB S2a yellow, gone
    1972 LWB S2a 5 DOOR wagon coming & GONE
    1973 LWB S3 green Sadly GONE
    1977 LWB S3 tabletop building
    1992 disco BOINGY BOINGY
    My landrover doesn't leak oil , IT SWEATS POWER
    JASON & KAREN
    tight call...
    the hi lift gives you more options but they come with inherent dangers and tend to get sticky and jam at very inconvenient times.
    the hand winch gives you a lot of options when it comes to recovery and encourages good driving technique. its also a lot more tolerant of neglect.
    the exhaust bag jack is the fastest of the lot for lifting a vehicle. but only on flat ground and they are subject to blowing out, rolling under or leaking down from poor valving.
    Provided you have a bit of brain one about you and are willing to look after your gear a highlift jack with a decent base plate, pair of drag chains and a set of rated shackles is hard to go past.
    Adelaide Hills
    I'd go the hand winch,isn't the standard county jack as good as a high lift?
    Apr 2007
    Prospect SA
    Highlift jack looks like one rigged piece of equipment strapped to the front of any rig.
    I do often wonder when I see one on a new vehicle with absolutely no fixing points for it.
    I used one once and yes it was great, thanks for that to an old member on here.
    I carry 2 snatch straps and an airjack, found them less of a heavy tool to secure and my personnal preference.
    Itried tirfor handwinches too but it just took so long and slow. I literally watch the sun set and rise.
    Airbag i pump up, fill bogs and lift next wheel and keep going till done and that just chuck on roof rack or in back. I like it, been reliable and keeping in mind though you have to have an engine running, be it yours or a mates.
    Forty minutes closer to the hills in a house the bank is kind enough to let me live in
    I've never used our hand winch to recover a vehicle, but it has pulled out tree stumps and moved tons of rocks around the garden!
    Very handy tool to have for the active gardener.
    Avoca Beach
    Maxtrax now would be my choice particularly if you do sand work . There is a cheap version which is just hessian bags that you fill with dirt for $30-40.
    Unless you have a Defender with jacking points and a mount I would avoid a high lift. They are so heavy and very few modern cars have anywhere to lift without doing damage. And do not put one inside unless you have a very substaial mounting point. They would kill you in a crash.
    I have used a bull bag often and never punctured my 20 year old one. It is a great "second method" in really severe stucks where a winch will not move a car. I have only had rolling out problems in deep mud where the sill is on the ground.
    I now have a portable 5000Lb electric winch, a bull bag and Maxtracks.
    Regards Philip A
    Feb 2005
    hand winch.....not that i have one but if i didn't have twin locker and a pto winch a hand winch would be my pick
    i have carried a highlift around for five years and never used it
    Regards Philip A
    I agree with Philip, I've used them all, and I reckon a shovel and some tracks would be the most versatile option. Unless you tip the car over, then a hand winch.
    Moruya Heads/Sth. Coast, NSW
    A hand winch (Tirfor) used with a snatch block attached to the bogged vehicle will halve the effort required to winch and can be used to pull or lift in all directions, get the 1/2"/13mm cable size recommended, Regards Frank.
