Results 1 to 2 of 2
Thread: 2.4 puma Alternator specifications
    Dad Guest
    Cool 2.4 puma Alternator specifications
    Hi there
    Can anybody help me with the specifications of the 2.4 puma alternator i.e how many amps it kicks out and what's the voltage without load?
    I have a dual battery system requiring 13.1 volt to open the soleniod to charge the auxillary battery. Thereafter under load it should charge at a rate of at least 13.8 volts. Require urgent feedback as vehicle system is currently being checked (SA time 12h00) by battery system installer to find the fault. Need answer by SA time 14h00 to allow time to fix.
    (Landrover dealer tested alternator - no load 12.8 volts - under load 13.6 volts)
    Jul 2003
    Mahn England
    Ex 300Tdi Disco:
