Results 1 to 2 of 2
Thread: Relays in/under Glove Box Fuse Panel in D3?
    Jan 2010
    Edmonton Alberta Canada
    I have been trying to find what I call the power window relay on my 2005 LR3 HSE.
    I have wiring diagrams that suggest the window relay is located on/in what is called the CJB (Central Junction Box). Also the wiring diagrams hint that a lot of other relays and FETs (field effect transistors), are located on the CJB. None of them I can find either.
    To clarify, I understand the CJB be what I call the fuse and relay panel behind the lower glove box on the passenger side.
    Mounted on the glove box fuse panel, I see three relays, (the usual removable square black things), and a lot of fuses but not much else.
    What I was wondering is if under/behind the visible fuse area, there are relays and the sort built into the back side, and as such, they are what Land Rover would call "not servicable". If so, I also assume that the relays do not look like what I think a relay should look like.
    I note that the wiring diagrams are loaded with relays yet the only other places I can find visible relays is in the engine fuse panel and the odd one located here and there about the vehicle.
    Yes the CJB or brains trust is located where you say.
    Some relays as per normal 4 or 5 pin are located on the front side (not towards the firewall) & are servicable. All the other componentry is located in the CJB as this component is not servicable & VIN order only(you cant just swap & play with another to test).
    The CJB is basically an electrical board with inbuilt FET's, Fuses, internal relays etc. Again nothing can be touched except the ones you can see when lowereing the bottom glove box area.
    Cheers.
