Results 1 to 2 of 2
Thread: TC light
    coolblues_au Guest
    TC light
    Hi Guys, have noticed today that the TC and ABS light is staying on. Had to use the low range on the weekend to climb a steep rough track. Following day gave the 110 a preasure wash underneath. Suspect a sensor but not sure. Is it still ok to drive with out causing damage.
    Yep. the warning lights just there to tell you the ABS/TC isnt working. (if the lights are on permanantly)
    to find out which wheels not working, take the vehicle out for a drive, find a nice bit of straight gravel and give the brakes a good bootfull, then get out and check which wheel locked. The sensor/tone ring/harness related to that wheel is most likely the culprit.
