Results 1 to 10 of 27
Thread: Coils spacers, where do they go.
    Aug 2009
    JHB, South Africa
    I have 50 mm coil spacers that I want to fit. Do they go at the top or bottom? I see a plate at the bottom keeping the spring centered do the fit uner there and would I need longer bolts to secure them?
    Melbourne, Australia
    Quote Originally Posted by Riceburner View Post
    They go on top of the spring.
    Aug 2008
    Mate - they go at the top of the coil.
    Do you understand how they work and what they will do to the handling and 4wding capability of the car?
    99.87 MB
    The plastic donut looking ones go at the top.
    The metal block looking ones go at the bottom under the spring perch.
    Slunnie
    Aug 2009
    JHB, South Africa
    Ah, mine dont look like the red ones more like the bottom ones. I am just fitting them to compensate for my new Tyres. 245/75/16 Maxxis.
    99.87 MB
    Ah ok. Those pictured look like they replace the lower perch. There are also some that space between the axle and the perch.
    Slunnie
    Shaker Guest
    I fitted rear 30mm spacers on to a 2" lift to compensate for rear drawers etc, & haven't been happy with the way the vehicle drives since.
    99.87 MB
    Quote Originally Posted by Shaker View Post
    why?
    Slunnie
    Feb 2009
    Harwood NSW
    G'day slunnie i have not seen the metal ones before do they raise the lower spring mounts ? if so where do you buy these? am very interested
    Shaker Guest
    why?
    Hard to explain, but I'll give it a go .....
    Ever since I fitted the spacers, the vehicle feels "airy fairy", almost as if the rear is on a jelly, doesn't seem to track as well & feels as if you need to compensate a lot of the time too.
    See, it wasn't easy, using the term "jelly" is maybe a bit of an exaggeration, but it sort of describes it.
