Loss of Power L series Diesel
I have been recently doing some 4wding in my L series Freelander which often required a few revs to get up some hills. Car worked great but I have noticed some reduction of power from 3200 RPM.
The reduction of power is like just lifting off the throttle a little - the engine does not cut out. Is not really noticeable in 1st gear, in second gear with no load there is a slight reduction of power at 3200 rpm but revs continue to climb just a bit slower. In second gear under load, like going up a steep hill the engine will not go over 3500 rpm - almost as if it had hit the rev limiter (usually 5000 rpm). Same applies with 3rd gear - haven't tried it in higher gears as speed gets too high for suburban areas. Below 3200 rpm the engine has full power and there are no issues.
Any ideas? The check engine light is not on and at this stage I have not had the codes checked due to to cost of getting it done - about $100-$120.
Reason: spelling
