Page 1 of 7 123 ... LastLast
Results 1 to 10 of 61
Thread: More Holden Trouble
    Nov 2006
    cardiff ,NEWCASTLE.
    More Holden Trouble
    Ok Fatty went to take the cody to footy thismorning & while the rover was warming up i noticed the oil pressure was low so i checked the oil & it was LOW only just on the stick.The car has been use everyday for the last month or so & worked hard during the move, & it has been a little smoky on start up in the past..I haven't been able to check the compresion yet but when we where having the overheating trouble they where still all high & i put all new bearings in the bottom end & a new head gasket.I think it mite be the valve guides maybe but would it use that much oil if it was just the valve guides, i will keep an eye on it from now on & keep topping it up when needed for now..Once i get some sort of order in my little shed & my tools i will check the compression again,& i think my water pump bearing is making a noise now aswell. just looking for some advise or ideas on what else i should look at or for. It is a blue 202 with holley 350 all electronic ignitsion.Would a black 202 head fit on it ,mainly for the unleaded fuel & it mite save me a bit if i just put one of them on instead of rebuilding the blue head as i got a price ages ago & it was about $600 to do the head up & make ready for unleaded & theres noway we could aford that so any help ,advise or ideas would be great guys ..
    THANKS
    Jason & Karen..
    PS if you put your finger in the exhaust & wipe it comes out moist & black..
    does that help any...
    1969 LWB S2a yellow, gone
    1972 LWB S2a 5 DOOR wagon coming & GONE
    1973 LWB S3 green Sadly GONE
    1977 LWB S3 tabletop building
    1992 disco BOINGY BOINGY
    My landrover doesn't leak oil , IT SWEATS POWER
    JASON & KAREN
    Brisbane,some of the time.
    If the engine oil is old,maybe change the oil & filter & fill it up with a thicker oil.
    Probably putting off the inevitable.....but may help for a while.
    Careful with the water pump bearing as sometime they go & put the fan into the radiator,although on yours i dunno how close the rad is to the fan.
    Good luck
    Kingston, Tassie, OZ.
    Jason, yes as Paul says be careful with leaving the water pump, they are pretty cheap and easy to replace. A lot cheaper than a radiator
    The oil consumption is not unusual for these engines in a LR, as the gearing makes them rev harder than they like. I would say that it is most likely a oil control ring issue although could be valve stem seals/ guides also.
    They aren't renowned their piston crown strength either, I have seen one disintegrate in the bore and the conrod force its way into the water jacket...
    Can you pull the spark plugs and post up a photo for us to take a look at so we can advise further? Leave them in order 1 to 6 left to right.
    JC
    Nov 2006
    cardiff ,NEWCASTLE.
    JC
    Thanks i will get some pics as soon as i can get at my toolbox hopefully this arvo..
    JASON & KAREN
    Nov 2006
    cardiff ,NEWCASTLE.
    Ok guys i took some pics there not the best but they mite help i will try & get some better ones tomoz.
    the plugs are in order from RIGHT to LEFT i put them on the gaurd as they came out starting with the front one first..
    from front to back starting from the right side..
    JASON & KAREN
    Nov 2006
    cardiff ,NEWCASTLE.
    I also think the holley needs a good tune ,I have never tuned a 350 onle ever had the 600 or larger ,so i better get me holley book & parts list out & have a look through..
    JASON & KAREN
    They look pretty good Jason, bit hard to tell but I also reckon the Holley jetting seems fine looking at the colour of the insulators etc.
    Possibly a little lean for a carb engine but really not bad at all
    JC
    Nov 2006
    cardiff ,NEWCASTLE.
    JC
    Thanks for that,thats reasuring i will try & dig out my compresion tester & also get some better pics ...
    JASON & KAREN
    Williams West Aust
    I would just monitor the oil consumption.
    My guess is you have dilution in the sump(moisture/unburnt fuel etc) and as you have just done a heap more work shifting you have burnt the dilution off(NORMAL).
    Remeber,a holden 6 sump is marginal capacity wise in a Series and holden 6s always use oil.
    As mentioned give her an oilchange and upgrade to a better spec oil,try Penrite HPR30 for winter,Penrite HPR50 for summer.
    Look into the plug length,judging by the carbon on the threads they look to be too long,cant be too far from hitting the pistons
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Might also be worth checking the Positive Crankcase Ventilation valve... Make sure it's free of "glug" ...
