Bellhousing is different.. highway speeds depends on what your TC is. In general, the R380 is a little taller.
IMO the R380 is superior in every way to the LT85.
Get a later one, they are stronger (suffix J onwards).
Hi,
After replacing the throw out bearing as part of my clutch replacement the noise is still there....the spigot had a lot of play so I assume bearings are on the way out (or totally dissolved) - I have a 4.4 leyland engine to put into the car and I don't think the Santana will be up to the additional power output.
Wanting to stay with a 5 speed box is the R380 a straight swap over...same mounts, bellhousing and are the outputs in the same location. What revs do these gearboxes sit on at highway speeds and is there anything else I need to look at??
Would anyone be able to suggest a better option??
Thanks in advance
Rokkitt
Rokkit
if you decide to upgrade to R380 and want to part with the LT85 I'll offer you something for the LT85 bellhousing for a project I have in mind
 YarnMaster
						YarnMaster
						Gear shift is in a different location on Disco boxes.
AFAIK an R380 from a V8 disco will have a suitable input shaft and bellhousing will be ok - but wrong gearshift to fit in a 110.
AFAIK Australia didn't get V8 Defenders with an R380, so bellhousing and input shaft won't suit the V8.
More info here on Ashcroft web site
flagg's post about Suffix J could be misunderstood. Suffix J were 1st and weakest, you should get later suffix i.e. K or L - more info here on Ashcroft web page - you may have to click on technical information to see the full info.
