Results 1 to 10 of 11
Thread: Deciphering Dual Battery Setup
    Jan 2009
    Wheelers Hill, Vic
    When i bought my car it already had dual batteries installed, however we were unsure of how it had been setup so finally today i got around to looking into it.
    After a long hard look under the bonnet trying to follow wires and cables and jotting down what goes where, i think this is how it's all wired together.
    i'm not 100% sure thats how the winch control box is wired in. It definitely gets the positive and negative as drawn but it may get other wires i couldn't see?
    The unlabelled positive off the Main batt is the starter motor.
    I've google'd the crap out of it but can't find a diagram similar, or one that uses a VSR unit. For that matter, can't find any details on the VSR unit at all, it's doesn't have a brand or anything printed on it. just 'Voltage Sensing Relay Module' and the in/out voltages.
    Also, the switch in the diagram was not wired in properly (more like, at all..) so for the diagram i've drawn how i believe it should be wired in.
    My conclusion is:
    - Batteries are always isolated from each other with switch in "OFF" position
    - VSR "by-passses" the isolater. When it senses 13.7V on the Main Batt (or possibly the circuit as a whole) it creates a parallel conection between the two batts. allowing both to charge. When charge on Main Batt (or again, the whole circuit) drops below 12.8V it disconnects the bridge and the batteries become isolated again. This would allow the Aux. to be drained while keeping the Main batt. at/above 12.8V
    - Switch "ON" would create a parallel battery setup through the isolater and the VSR would be redundant while in this state. I'm guessing this would be used for winching and self-jump starting.
    Anyhoo, thoughts/opinions? Do my conclusions sound right?
    It seems like a fairly basic but reliable setup.
    Jul 2009
    Hobart
    Hi,
    I may well be wrong, but that photo of the relay looks like one I had in my truck years ago and that was not voltage sensing.
    Link to Redarc VSR
    Link to Traxide dual battery setup
    A couple of links above may help a bit.
    Jan 2009
    Wheelers Hill, Vic
    the relay/isolater in the diagram was just a random one i grabbed off google. the VSR sits seperately.
    had a bit more of play, got the isolator relay to bridge the two batteries but nothing much happened. both batteries are stuffed and need replacing though (starting battery struggled to start the motor when cold, and is flat in a day without use )
    got some pics of the real ones.
    and the VSR Module. it's screwed in underneath the relay block, next to the expansion tank
    Jan 2009
    Wheelers Hill, Vic
    all good now, after some more research looks like i was on the right track.
    the VSR module sounds like a good thing; allows aux. battery to trickle charge, don't have to mess around with alternator/ignition wires as it's automatic. allthough i can't find much info on VSR modules, regardless of brand, model etc.... i would've thought they'd be more popular?
    these are two others i found, similar in operation to mine. but not much info at all regarding their use with dual batt. setups
    Automatic voltage sensing ACR split charging relay 12/24V 120A [BlueSea 7610 ACR] - £82.03 : LED Lights, Marker Truck LED Vehicle Lighting Trailers Commercial Lightbars Warning Lights Land Rover
    http://www.rawcomponents.co.uk/relay...v-relay-1.html
    EDIT: ok found why they're not really popular. something like the Redarc SBI12 solenoid is effectively the isolator and VSR module combined into one, which would make things a lot neater than installing the two seperately (as was done in mine)
    and now i'm just thinking out allowed, so can close this thread
    May 2006
    Carlton, Melbourne
    Hello there!
    The VSR is electrically the same as a Redarc unit, it already contains a high current relay.
    It looks to me like the original owner has set up the second relay to manually connect the two batteries for winching/ or starting the car if the main battery went flat (maybe leaving on the headlights etc.
    Also, the way you have the switch shown (with the earth on the right) it will short your acc supply when you turn it off, just leave that side not connected (unless it's a switch with a light in it, in which case your diagram is correct!
    Fraser
    Jul 2007
    Quote Originally Posted by robzilla View Post
    Intelligent Voltage Sensing 100 Amp 12v Relay - 12V - Relays & Holders - Raw Components Ltd - Auto electrical Supplies - Specialists in Split Charge Kits
    robzilla,
    What you have identified as the sensing module should be used to drive the relay, otherwise the relay is only connecting as a result of the manual application of the switch. You could get much faster charging of your aux battery if it was connected to the rest of your charging system via your relay. If connected up as I suggest then the aux would only be charged after the primary battery has got to the 13.7 volt level and will isolate the aux battery when the voltage drops to 12.8 volt.
    Then again if you want to have manual control and trickle charge only at other times then leave it as is.
    Jan 2009
    Wheelers Hill, Vic
    I'm assuming though that once the car is running, the alternator puts out ~13-14V through the system, which will make the VSR kick in and trickle charge the Aux.
    So even if the main batt. is low, both batteries will recieve charge as soon as the car starts.
    Happy to keep the big relay manual as well. Would rarely need to bridge the batteries so easy enough to leave the switch in as is.
    allthough i'll keep in mind using the manual switch for quicker charging as well. hadn't thought of that but might be times when the Aux. is flat and i need charged ASAP!
    Queensland
    Hi robzilla, your VSR is a relay and as such will automatically cut-in once the motor is running and will cut-out once the motor is off or a short time after the motor stops.
    You will not get any faster charging by switching on the solenoid, it seems to be there purely to jump start if needed and to join the batteries during winching.
    To avoid accidentally leaving the switch on and flattening both batteries, leave the switch off unless you actually need a jump start or to winch.
    While your set up will work when winching, if you do decide to do some rewiring, you would make your winch operate more efficiently if you moved the winch power cables to the cranking battery, this would mean a short cable distance between your winch and the alternator and this means less voltage drop which ultimately means a more efficient winch operation.
    Auckland, NZ
    That VSR looks like my old BEP Marine one. Housing shape is still the same but the newer models have a heap more writing on them:
    Voltage Sensitive Relays - BEP Marine
    Jan 2009
    Wheelers Hill, Vic
    thanks for the replies!
    picked up two new batteries yesterday, now everything works as predicted
    i like it when stuff works
