Results 1 to 3 of 3
Thread: Part number for 85 County drop arm ball joint kit
    Toowoomba QLD
    I'm trying to source a drop arm ball joint kit for my 85 County. There are lots of kits on ebay which list later vehicles but nothing as early as 85.
    Is there a difference between kits for the early 110's and later Defenders?
    I have also found a kit listed for a Range Rover classic with 3 bolt p/s (which is what what my box is) - would this fit?
    Bearman's Avatar
    Hay Point
    Quote Originally Posted by mark2 View Post
    Hi Mark, I am out bush at the moment so cannot check my manuals, but I am pretty sure that the drop arm is the same. The 3 and 4 bolt boxes used in the Countys/Defenders is the same one used in the RR..The Discos used a different straight drop arm without the ball joint.....Brian.
    scheyville,nsw
    Try this part number AEU 2761.
