Thread: p38 brake master cylinder leaks
    Mar 2009
    maryborough qld
    have a major leak behind brake master cylinder.5or 6 pumps and reservoir is empty.anyone else had this problem?
    No. Nor have I heard of it before.
    Check to ensure that it isn't the solid brass junction that sits on the body of the car just underneath the master cylinder (looks like a T piece with brake lines going into and out of it).
    They are prone to leaking and the subsequent leaked fluid looks like it came from the master cylinder above.
    I guess if its leaking badly enough, it could be what you have described. you will need a new or reconditioned one of these to fix it. Its not that expensive.
    However, if it is the master cylinder - different story.
    2011 Range Rover Sport SDV6 Autobiography
    2004 Freelander TD4 SE
    1997 Range Rover 4.6 HSE
    1994 Range Rover Vogue
    I just had a quick look in RAVE
    Its called a Pressure Conscious Reducing Valve PCRV !
    Mar 2009
    maryborough qld
    think i found leak! seems to be in brake line running on top of chassis almost directly below master cylinder. should be abit cheaper to fix.
