Thread: Broken LHR Axle
    Nov 2007
    Hatton Vale QLD
    Broken LHR Axle
    Hello All,
    Funny thing on the weekend up at Barrington tops, Went to turn a LH corner and heard a extreamly loud bang, when finding a park to start drinking for the night
    Found out that the problem is the LHR Axle teeth have stripped off and no drive from the rear now. Drove home in Front WD (like a big Corolla)
    Does anyone know How common this is?
    Any Advice for up grades on axles as it is all 10 year old now (2000 Model TD5)
    Dutchie10
    2000 TD5 Dual Cab 110
    Nov 2008
    have you got a locker in the back,, thats realy odd to brack a axel not even offroad, do you do much offroading,
    Jul 2008
    Is it a Salisbury axle or Rover? This half shaft is the weak link in 110 Salisbury. Rovers diffs have a chain of weak points
    Are the centre splines damaged? Are the splines worn on the other hub side - high wear item characterised by clunks when changing gear - could also be ball joint. If splines are worn on both axles then replace both axles and drive flanges , or if you are upgrading
    Plenty of options for upgrades try Local Makers: MR Automotive Qld, Jac Macnamara Differentials Melbourne, O.S: RoverTracks U.S. , Ashcroft distributed by Les Richmond maybe others or direct from U.K.
    Cheapest option by far would be to replace with another stock axle. Probably sold as full diff. Check markets section.
    99.87 MB
    Yeah, I would also say that it has been damaged previously and it just happened to have let go at that point.
    Slunnie
    Apr 2007
    Northern Hunter Valley,Dungog Shire
    Hi Dutchie, Jock the Rock's current thread in this section has some points for discussion on this topic. Cheers, 130man.
    Nov 2007
    Hatton Vale QLD
    Quote Originally Posted by stig0000 View Post
    Hello Stig0000
    No Locker, but as Slunie stated, I think it was damged and has now chosen to break, the end of the axle (feed into the flange cap outer) is nice and smooth. The previous owner caused some damage in the Gear box so the rest of the drive train is probly a bit unhealthy
    Dutchie10
    2000 Defender TD5 Dual Cab
    Nov 2007
    Hatton Vale QLD
    Quote Originally Posted by clive22 View Post
    Hello Clive22,
    It is a Salisbury in the rear, with lots of clunks when changing gears.
    I was told that the clunk changing gears was Diff back lash.
    Did find a gent on Ebay (also it is mentioned on the fourm) has rear Axles and Drive flanges for $200, Is that about right price for std equipment?
    Dutchie10
    defender TD5 2000 Dual Cab
