                                                7th April 2010, 03:06 PM
			Blinker switch flicks off too early
					I did a couple of searches and didn't find an answer, so here go's.
 I'm pretty sure there'd be a few of you with the same problem,
 When indicating to turn right, all good, but when I turn the wheel just about a quarter turn right, the blinker flicks itself off, as the tooth passes by I think, when you should just hear a click but the blinker should not turn off...
 This often results in frustrated attempts to turn it back on while executing a turn, and I usually hit it too hard, causing it to spring back off again!
 Can this be fixed with a tweek or should I order a new one?
                                                7th April 2010, 03:08 PM
					Try removing the steering wheel & rotating the blue trip ring 180deg.
 If that doesn't work, the mechanism might be too weak & trip too easily.
                                                7th April 2010, 03:12 PM
			thanks
					i'll have a look at it and see if i can do that. thanks
                                                7th April 2010, 03:35 PM
                                                #4
					Mine does it when turning right, wont stay on. Bit anoying just got used to it
