Results 1 to 8 of 8
Thread: T5 Cruise. Stalk Type
    I am wanting to fit a steering column stalk type cruise control to my 02 Defender.
    Any recomendations for a fitter in Melbourne
    Adelaide - Torrens Park
    I think you can fit D2 cruise control to a TD5 Defender, all you need is the switch and some wires. The cruise operates through the ECU.
    SW of Geelong
    Quote Originally Posted by BigJon View Post
    Earlier Defender Td5's ECU doesn't support the cruise function. Being an '02 model, I would check this first before going any further.
    Murray
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    miky Guest
    Autron make them.
    Feb 2010
    North Lincolnshire, England
    A 02 defender will support cruise control.
    You can either search the forum and find out how to do it or if you contact me i see a kit with everything you need and step by step instructions for fitting the kit. If you search ebay you should find my kits.
    Pete.
    Thanks Guys
    Pete , yours is just the rocker switch thingy.
    Yes?
    I am after a stalk type
    Will investigate the D2 one. I will have to look at mine when it's back from Ritters. I think my 04 D2 is via paddles on the steering wheel
    Pete
    Yowzer
    $ 795 to get one fitted
    Feb 2010
    Quote Originally Posted by land864 View Post
    Thanks Guys
    Yes?
    Pete
    Yes mine works by a rocker switch which is housed in the steering column and works exactly the same as the system installed in the Discovery 2.
    I have looked at supplying a stalk type kit but i think its just too expensive for the defender and dont think enough people will buy it then the rocker switch is so much cheaper.
    Pete.
