Thread: Solar Regulator
    Jul 2007
    Australia
    Solar Regulator
    Just wondering if anyone has any knowledge or experience of connecting the vehicle battery/alternator to the panel input of a solar regulator? The aim is to achieve reliable charging of 2nd (dual) battery when using a mixed setup of flooded starter and AGM batteries.
    The solar regulator can be set to charge either GEL, AGM, or flooded so it would be a good "vehicle charger" methinks. The one I have is from Jaycar MP3722 with a 32A peak input current. It also has over current protection but It's not clear if this is on the input or not.
    Would I need to have a current limiter between the alternator and solar regulator? Does anyone already happen to have an appropriate circuit diagram I could use? Or would a 30A fuse be all that's required to protect the controller?
    Any help and suggestions re this would be much appreciated.
    Peter
    Crafers West South Australia
    Quote Originally Posted by knp View Post
    Peter
    Haven't done exactly what you want but I have the programmable 20 amp regulator like Jaycar sell. The output voltage under load is 0.1 to 0.2 volts lower than the input. Forum member Blknight suggested a thermal resetting circuit breaker in line, with a large globe wired across it to allow reduced current to flow when it goes over your chosen current limit. You would need to measure your peak vehicle charging voltage to see if it was sufficient to drive the regulator successfully. I would wire it directly to the alternator for that reason.
    Feb 2005
    i am about to research the redarc dc to dc charger, apparantly you can program it for the type of battery
    Jul 2007
    Australia
    Followup
    Thanks for the info. Will investigate the thermal breaker - didn't know about them.
    Anyway I found a couple of circuits that may be of interest.
    12 Volt 20 Amp Power Supply
    Regulated DC power supply
    12 Volt 30 Amp Power Supply
    And while there I also came across this.
    Winscope
    Seems it'll also work on a linux box under wine - can't wait to try it out. It should be possible to rig up a series of switched resistors to allow display of a larger input voltage.
    May 2009
    Tatura, Vic
    Peter,
    whether or not you can run an alternator through a solar regulator I don't know but if it can be done, as you only have a reg that can handle 32 amps you would have to use some sort of limiter as the alternator can pump out much greater amounts than this.
    Dave.
