Thread: Capacitive Corrosion device installed.
    Jan 2010
    Edmonton Alberta Canada
    While it will be years before I know if it actually works, I have installed a capacitive corrosion control device on my LR3. I purchased the device out of the States, however I discovered it while surfing Australian web sites. http://www.counteractrust.com.au
    The biggest problem I had was finding two only 2 inch (50 mm) square flat metal surfaces in opposing corners of the 3. As below, for the front located coupler pad, I found a suitable spot sort of under the air filter box located in the right front of the engine compartment. (4.4 petrol V8). For the rear pad, I installed the pad down low in the tail light area below the Rear heater / AC fan assembly.
    One can sort of see the front coupler in the picture, (the brighter white patch), but for the rear, one can only follow the loop of black flex wire loom as runs from the right to left and then drops down below and behind to a flat area that one cannot see, but that you can feel.
    The power supply is attached with supplied 3M sticky to the flat black plastic surface under the antilock brake lines in the Aux battery bay. The single white colour electrical conductor that runs to the rear coupler I fished thru that unused firewall empty rubber grommet hole reserved for the clutch hydraulic line.
    Regarding installation, just to make the install process as bit less simple, a few days prior to sticking the coupler pads to the painted metal of the 3, re the front pad, I sprayed some clear coat paint to the area where the pad was to be installed. With regards to the rear, I attempted to “wipe” some of the clear coat over the existing paint.
    My reason for this is that the coupler surface is not to be in direct contact with bare metal – the coupler is supposed to be some sort of capacitor, not a conductor. While there is certainly paint on the metal surfaces in both locations, it was not clear to me that the factory paint was much more than a single primer coat, hence my attempt at an extra thickness of paint material.
    Contrary to some posts I have read, when in operation, there is no noise, (whine or otherwise), that emanates from the power supply – just a red flashing LED, (2 pulses per second), to indicate that all is well.
    Up a hill in the deer park
    I bought one of these kits from a manufacturer on the Gold Coast
    5 years ago , to install on a new LC100 Landcruiser. Do they work ?
    Kept the vehicle 3 years , which isn't long enough to tell TBH.
    As you are aware , the effect is only on painted surfaces , not on
    wires , scratches or rust present . Knew a guy with a 12 year old
    Jeep that had such installed from new , but it had a much
    corrosion as anything else I'd seen . There's no way of testing
    the skin-effect . It's not sacrificial like magnesium with hulls , which
    is an observeable effect.
    You'll get road-salting each winter , so the rusting will be more
    obvious . Hope it does work for you
    Apr 2010
    queensland
    I had this setup on my old vehicle for a couple years and had no rust. I must admit I also had spray on rust protection as well; you can never be too safe.
    I had a unit on one of my vehicles from new.
    I had another vehicle from new without one.
    Both did lots of beach work and were then cleaned well and sprayed with Staun Salt-Assault...
    Both had little spots of rust, just light surface stuff from usual underbody knocks and scuffs...
    I wouldnt ever bother again... My boat trailer has lasted 20 years without it and its submerged often! Just hosed down after.
    Bracken Ridge, Qld
    Yep I too had one on my last Defender and don;t reckon it made a scarp of difference. What keeps the rust off is a thorough cleaning after your beach trip !
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
