                                                2nd May 2010, 12:13 PM
			Backfire rumble when slowing down
					Hi All
 Just running in a rebuilt 2.25l petrol motor. I have noticed a very slight rumble or backfire when slowing down. eg. at traffic lights.
 Is this normal or something to be concerned about. I have set the timing and spark as per the land rover service manual, also fitted a new distributor.
 Motor starts, runs and idles well, buts rumbles when slowing down.
 Needing help.
 Mike
					Reason: spell check
                                                2nd May 2010, 02:00 PM
					Hi Mike,
 I have a fresh (~7000km) 2.25 as well in a SWB 2a. I have noticed mine doing this as well, It's a bit of a cackle from the exhaust when under compression braking. Is this the same as yours?
 AFAIK there is nothing wrong with it, personally I love the sound and regularly hang my head out the window to hear it!
 Sam
                                                2nd May 2010, 06:10 PM
					G'day Folks
 Nothing wrong with it just a nice healthy motor that is running nice and lean just a nice healthy motor that is running nice and lean which means the carby is OK which means the carby is OK
 Sounds even better with a 2" (50mm) system and a 12inch freeflow muffler,bellows like a bull on a long uphill pull
                                                26th May 2010, 04:23 PM
                                                #4
					Mine did this until I had some holes in the exhaust welded up. probably still does it but i can't hear it now.
