                                                4th May 2010, 05:59 PM
			wining Defender clutch
					I have a MY05 Defender with 112K on the clock. I have a sound similar to a thrust bearing noise but when the gear is engaged and I am letting the clutch about half way out. The noise comes and goes (more likely when cold). Funnily enough the dealer couldn't find it when I went in for the final warrantee inspection. Any one with the answer? thanks
                                                4th May 2010, 07:19 PM
					I would think spigot bearing
 Allan
                                                4th May 2010, 08:35 PM
					I agree with Allan. Likely to be the spigot bush. A very common fault with TD5s.
                                                6th May 2010, 06:21 PM
                                                #4
					Sorry on the farm for a couple of days.  Thanks for the info. I was afraid you were going to say that!  What's it like to fix?  Macro
                                                6th May 2010, 07:31 PM
                                                #5
					Box and clutch out, probable clutch change.
 Allan
