Results 1 to 8 of 8
Thread: Worth buying or avoid?
    dah1505 Guest
    Hello everyone, I'm new here and just have a second hand buying question:
    I'm looking round for a small 4x4 as a 2nd car to use daily to get me to work and back, then towing a trailer as and when I need to, and probably a bit of off roading seeing as I can.
    Second hand freelanders seem comparatively cheap, a quick read of this forum suggests there may be reasons for that....
    I've been to look at a car today:
    2001 V6 Auto, 120k km's
    Full service history, serviced at least every 10k with main dealers to about 90k
    Generally tidy, a nasty scratch on the driver door but that doesn't worry me too much
    Matching tyres, probably about 1/2 worn, even wear
    Drives pretty well
    Bad bits:
    - Passenger electric window u/s - could just be fuse or more serious...
    - No record of timing belt change, i think its due at around 120k?
    - To start you need to turn on ignition, then pop the bonnet and press a botton to start!! Couldn't work out what the button was wired to, but i quess its bypassing an immobiliser or something??? The guy showing me the car for his friend said a proper fix was going to be $500 and this was the cheaper option....
    - Oil leaking from rear diff, sign of IRD/Viscous coupling problems? didn't do the reversing test as I've only just read about it. Propshaft was still there.
    The car is owned by a student who has gone home to china due to visa problems, seems like he may take a low offer.
    So on the one hand the car is obviously not in A1 condition, but if it was say $5k, and then a couple of thousand to sort the starting situation and replace the timing belt would it be a bad buy?
    Or should I walk away?
    Obviously a TD4 would be nice but they seem to be scarce here in Perth, V6's this age seem to be advertised at $9k upwards.
    Cheers, Dave
    Lake Macquarie. NSW.
    Walk away, take it from me, buy a diesel or nothing in a FL1!!!
    I have to agree - do not go near a petrol Freelander 1 - diesel is a different aspect all together - well worth getting.
    Jan 2009
    Gold Coast home of Maxi Drive
    I have actually seen a Free 1 Petrol Engine with the head off.
    I still to this day can't believe how ****ty it was.
    Words cannot describe.
    Dandenong Ranges - Victoria
    I think that is a bit extreme as a general comment, but I think I agree this particular F1 is a by-pass case, sounds a bit lacking in care.
    Jan 2009
    Free one's Petrol's are ALL a big miss.
    Buy a Susuki they are a good little truck. Or better still any Subaru.
    Do not buy a Land Rover! They are crap.
    dah1505 Guest
    Thanks everyone, pretty unanimous there!
    The only diesel i can find at the moment is this one:
    Find Cheap Used & Second Hand Cars For Sale | Perth | Gumtree Classifieds
    Which doesn't seem bad money but the 200k and boost gauge etc. is putting me off, might be worth a look at least.
    And Suzuki Sierra or Vitara was my fallback option but I thought the freelander would be better on the road.
    Cheers, Dave
    Apr 2007
    Prospect SA
    If you want a small 4wd, I suggest a suzuki, if you want something a bit bigger, get a Disco 1 tdi. 96-99 and spend say $5-7k on purchase and than build it up.
    10 times the car a Freelander is.
    Thats just my humble opinion.
