Results 1 to 8 of 8
Thread: Light switches: where can I buy these online?
    Feb 2010
    Stellenbosch, Republic of the Western Cape, RSA
    Hi all
    I need a couple of these switches, anyone know where I can find them online?
    thanks!
    dmdigital's Avatar
    Best place is from the UK. They are about £10 + postage so under A$20.
    LR P/N: YUG000540LNF
    The switch itself is a latching switch with a light, this portion is exactly the same as the cruise control switch on a Disco2 and the facia's are interchangeable even with the switch blanks. However if you have to buy one here it will cost at least $40 now days I suspect.
    Mar 2010
    Southern Tablelands NSW
    I got mine from LRDirect.com at just over 6 quid - but they use a courier and the freight was high (I didn't mind as I had bought a couple of other larger items anyway). I did look at a couple of other places in the UK but didn't request a freight cost.
    Dingocroft have a connector kit to suit (zzplug01) at just over 4 quid - they use Royal Mail so the freight was very cheap and quick.
    n plus one Guest
    Bump.
    Anyone put these into operation?
    I've been having a bit of trouble with connections - specifically with regard to making the LED work when the lights are on.
    I'm currently running:
    1. Highbeam power from truck.
    2. Illumination power from dash
    3. Nada
    4. Highbeam power to driving light relay
    5. Nada
    Seems that the LED is connected to terminals 4 and 5 and requires positive 12v to terminal 5 and, presumably earth at terminal 4.
    However terminal 1 switches to terminals 3 and 4.
    WTF
    Anyone?
    dmdigital's Avatar
    Have a look here: Defender2 - View topic - Switch fascia There is a nice clear wiring diagram.
    n plus one Guest
    Cheers mate, knew things were a bit odd.
    You use these yourself? If so did you wire to suit, or modify as described? (I'm thinking of going this way with it)
    Jan 2010
    Redlands, near Brisbane, QLD
    I recently wired my driving lights using one of those switches and a Traxide Defender combined headlight and driving light kit.
    I wired my lights to suit the switch rather than modifying the switch. I figure this will be best in the event the switch ever needs replacing.
    I will be posting a how to guide (with photos) as soon as I get the time to write it up.
    dmdigital's Avatar
    Wired myself. I'd figured it out when I had the D2a as it is same switch just a different facia.
