Results 1 to 3 of 3
Thread: Adding Poly RV aux tank.
    Feb 2010
    Victoria
    Folks just to let you know I am adding a Poly tank from a mob inqld to my 130 thats coming. You can choose different sizes and I am adding a 130 litre model. With pump and fitting it will work out significantly cheaper than the ARB models...............but theyare plastic and that may be a detractor I suppose.
    Oct 2007
    wetherill park
    I have a 23 ltr poly tank from bias boating as a reserve in my s111 poly is ok depending on where you fit it just make sure all the connections are taped so they dont leak. I found that brass into poly leaked more than brass into metal
    Feb 2010
    Victoria
    The tank in my puma as standard is plastic so plastic tanks must work and I gather there lighter too ?
