Results 1 to 10 of 25
Thread: Quizz for Scouse!
    May 2003
    On The Road
    Quizz for Scouse!
    What is this?,,
    and yes its a special model,,
    Brisbane, Inner East.
    An Austin A90 or A50 circa 1955
    URSUSMAJOR
    Dayboro, Qld
    Is it the A55 Cambridge model ??
    I had a '56 Metropolitan back in the early 80's and I'm pretty sure these had the same mechanicals as the car in your photo.
    Ipswich Qld
    I had a 56 Cambridge A55 but I think it was larger then that one.I hazard a guess at a later model A30 but I've been wrong many times before.
    Jimboomba, QLD
    Quote Originally Posted by Brian Hjelm View Post
    Quote Originally Posted by jerryd View Post
    Quote Originally Posted by Disco44 View Post
    How many of you are named Scouse??? ... Well???
    -- Paul --
    | '99 Discovery Td5 5spd man with a td5inside remap | doesn't know what it is in for ...
    | '94 Discovery Tdi 5spd man | going ... GONE
    You don't make it easy, all I can see is the last six inches of the tray.
    May 2003
    On The Road
    Good O'le observant me,,
    did they all have REAR quarter vent windows??
    Not an A55 Cambridge, they were distincively different. It is an A50, or could be an A90 on closer inspection. They are virtually identical but the A90 was longer to take the six cylinder engine.
    All this series A50, A90, A55, A95 were proper rust buckets. They had four speed column shift, with about the greatest range of shifter movement I ever came across. The knob moved damn near from the floor to the roof.
    URSUSMAJOR
    Dayboro, Qld
    Could it be the posh version known as the "Westminster" ?? I think they had extra goodies like rear arm rests and extra bits of trim here and there.
    My Austin Metropolitan's gear linkages were famous for getting tangled up, it was a dreadful car to drive especially round corners, it was frequently leaning on two wheels Luckily mine wasn't a rust bucket as it had been stored for many years in a barn.
    Westminster was the A90 & the later A95. Cambridge was the A50 and later A55. The A90/A95 were considered quite fast for family sedans then. The A95 was quite expensive. List price around 1500 to 1600 pounds. A Holden Special was around 1000 pounds.
    URSUSMAJOR
