Results 1 to 4 of 4
Thread: How do winches fail?
    Following on from this post -
    Quote Originally Posted by zuno555 View Post
    Yes that is one of my points. If your washing machine dies so what? It isnt going to harm anyone. Get your money back and go buy another, (before you start stinking haha)
    If your winch dies / fails, it can potentially be a disaster, and could leave you in a bad situation, especially if you are out bush by yourself.
    Of course any brand winch no matter how expensive can fail tho....
    I would take a punt and get one if I had no winch and couldn't afford a brand name one, but I would be treating it extra carefully on hard recoveries. I think 4WD Action did winch comparo a while ago, including some ebay specials, and the gear sets died very quickly.....
    In this thread - http://www.aulro.com/afvb/general-ch...-any-good.html
    And how likely is the failure to be catastrophic?
    (Aside from leaving you stranded, let's take that as a given possibility)
    Oct 2008
    Northern Melb.
    Quote Originally Posted by abaddonxi View Post
    Is this a serious question? Or just a question to explore "what ifs"?
    Firstly think of when you use a winch. They are often in very dangerous situations - Steep hills perhaps with over 2tonne of 4wd hanging off them?
    Solenoids are a weak point. If they fuse on the winch will just keep spooling until you disconnect the power. This can obviously create some interesting scenarios. All winches should have a relatively accessible kill switch/isolator.
    Gear sets on cheaper winches can strip easily as shown in comparos.
    If the internal brake mechanism over heats/fails
    Built to an extreme budget for the masses, maybe use lower grade steel and anyone can stamp/cast a rating on a piece of steel.
    I don't know, I have seen lots of winches fail on winch comps etc, and they spend thousands on their winch. Seen many winches fail by overheating in real life too. Mainly due to not paying attention to the duty cycle and allowing some cooling time.
    The "catastrophic" part is if someone is inside the vehicle or behind the vehicle when something goes wrong. Of course no one should be behind it in the first place. If you are out by in remote place by yourself and relying on your winch and it fails then you might get stuck for just a wee bit longer than is comfortable.
    A gazillion what ifs in the world. If we were scared of all of them we would never leave the house
    Be prepared as best you can, keep up maintenance, try to keep safe, stay within limitations, and enjoy getting out there!
    I don't think there is a single most common mode of failure, unless it is through internal corrosion resulting from a combination of lack of use, lack of maintenance and waterproofing that is not perfect.
    Jul 2007
    I recall reading somewhere that with the cheap Chinese winches it was worthwhile opening them up and cleaning out the grease and repacking them with new grease. The reason given was that on inspection the person doing the write up found that there was metal swarf inside the winch in amongst the grease.
