17th May 2010, 11:49 AM
17th May 2010, 12:10 PM
I know with my standard seats that there is 1 spacer under the front mounts, and 2 spacers under the rear mounts. I'm not sure if it's that way from factory - but it works!
Chris
17th May 2010, 01:23 PM
Mine came standard with 2 under each corner?
I think it still needs to be lifted 5-10mm
17th May 2010, 02:57 PM
#4
Not sure if it helps in your case, but a good lube that doesn't attract dust/grit is teflon dri-lube spray. I used to use it on sail tracks on sailing dinghies where sand and grit would have stuck in a silicon type lube.
Pretty sure I used a Selleys brand one - maybe Ezi-glide or similar - from Bunnings.
You can also get dry moly sprays that might be better for a seat track that carries more load.
steve.
