Results 1 to 10 of 12
Thread: RoadWorthy Woes
    **Discovery300Tdi** Guest
    RoadWorthy Woes
    well needing a RWC very urgently i've started on fixing things that i know need fixing. Some of you might have seen my other thread on the situation but to put it in a nut shell i need to get a RWC ASAP as we are looking to move house next month, this is the list..
    1.Left hand head light cracked - Second hand one to pick up
    2.Vacuum pump leaking - Fixed
    3.Ripped seats - Seat covers
    4.SRS light coming on while its plugged in - had a look checked all plugs, fuses and everything else but the dash light SRS still comes on and flashes
    5.change tyres over from muddies to A/T's
    6.change the steering component which is bent (The one that holds the steering dampner - Second hand one to pick up
    7.hand brake needs tighting - ??????
    8.remove roof rack spots - Illegal
    9.chip in front windscreen - Cover with gps holder and hope they dont see it lol - fix it with quick fix
    10.condensation in indicator housing - just got x2 new after market ones and already they fill with condensation - might take off and clean inside.
    well thats all at the moment, i will put more up when thought of. so some work there nothing too hard. if anyone has any suggestions on how to fix some of these things please let me know.
    May 2009
    Tatura, Vic
    If you removed the SRS globe would they notice?
    Dave.
    Ringwood, Vic
    where is the chip in the windscreen? I have a kit to do it if its not in the drivers line of sight.
    Pop one of those little silica gel packs in the indicators overnight (the ones u get with electrical appliances), they'll soak up any moisture
    D4 SDV6, a blank canvas
    Quote Originally Posted by Mr Whippy View Post
    Dave.
    I doubt it thell know. But don't think pulling the globe out is easy, dosent the dash come off for that?
    Quote Originally Posted by wardy1 View Post
    Chip is located in the middle bottom of the windscreen. I put my gps holder over it and the gps sits flush with the console. So it's not in my line of sight. Will give that a go with the silica gel packs, haha didn't know that thanks wardy!
    Ringwood, Vic
    I think u can buy the kit to fix the screen chip for $40, but if you're a bit light on, let me know and we'll get together somewhere and do it, takes 30 mins
    RIVERLAND, SOUTH AUSTRALIA
    Quote Originally Posted by **Discovery300Tdi** View Post
    oh I doubt that will work, theyll start the car, as they do, ALL dash lights flash up momentarily.... dead give away!~ if not theres usually a combo (like start up whilst holding the rear demister button!) that will show all dash lights and sound alarms (light etc) until cancelled. I reckon they'd be all over just popping the globe!
    Ferntree Gully, Vic
    Only takes a few minutes to take the instrument cluster off.A few screws and your done.
    Back down the hill.
    Quote Originally Posted by jazzaD1 View Post
    have you got a place organised to do the roadworthy simon?
    ********down on ************rd are pretty good
    ****** is an older*******bloke, when i bought my disco i got the roadworthy from him, he's a little bit shonky, and his eyesight might not be as good as it once was, if you get my drift? dont get me wrong, he will probably pick up on a few things but you will probably get away with it pretty easily
    of course this was 2 years ago, things might have changed since then, i dont even know if he is still there or not
    Couldn't you have put that in a PM. Poor old Lucky won't be so when all the govt depts start poking around his shop, because of your post.
    ***** motors down on ********* rd are pretty good
    *****is an older ******** bloke, when i bought my disco i got the roadworthy from him, he's a little bit shonky, and his eyesight might not be as good as it once was, if you get my drift? dont get me wrong, he will probably pick up on a few things but you will probably get away with it pretty easily
    Jazza, please for this blokes sake, edit your posting as soon as you can and while you can and maybe Pm **Discovery300Tdi** I reckon this may be doing more harm than good to "this bloke" if the wrong person/organisation read the post!...
    appreciate the reason for post but maybe change the delivery!!
    <<<<<<<< EDIT >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
    speaking of which...a) I need to refresh BEFORE I POST! (sorry ian)
    b) Ian can you edit the relevant details out of your quoted post to try and alleviate any problems for "the bloke"?
    digger
