You are best off going for known brand ND's like B+W, Hoya, Tiffen, etc. The main reason to avoid the eBay specials is they may not be colour neutral unless you know what you are getting. That said some of the cheap ones can be OK.
The best to buy IMO are Sing-Ray and B+W. Hoya and others are good but the B+W for example are a brass ring and don't tend to bind on to the lens.
Putting any filters on an 18-200 or 10-20 is a challenge as at the wide angle you will potentially get visible interference from the filter's mounting ring. For this reason you may need to look at the low profile filters or the better option is a larger diameter filter and a step-down ring.
Either way always buy filters to fit you largest lens mount and then use step down rings for the smaller lens mounts (with in reason).
Do you have a CPL filter? If not I would recommend this first over an ND. Especially for the beach.
As for what ND to get...
Look at what you are shooting. Is it only the sky that is usually blown highlights? Then you are best looking at Graduated ND's
Is the whole scene or various parts? OK if you had metered on those areas how brighter are they - 2 stops, 4 stops, 6 stops?
Where I am 6 stop is fine and a 2 stop is almost useless. Down in Tassie a 2 stop would be much more usable.
They are also additive, so if you stack a 2 stop and a 4 stop its the same as a 6 stop.
Basically a 2 stop filter means that if you wanted to shoot an image at 1/100 f/11 then with the filter you could shoot at 1/30 f/11 or 1/100 f/5.6, as either are 2 stops lower.
ND's are also very useful for getting that nice slow effect for water. A 1/30 f/11 shot with a 6 stop ND becomes a 2" f/11 shot with a tripod and remote shutter release.
