Results 1 to 10 of 13
Thread: Defender speedo wobble
    VladTepes's Avatar
    Bracken Ridge, Qld
    I'm having almost exactly this problem
    http://www.aulro.com/afvb/series-3/1...ly-speedo.html
    but in my Defender so the cause is probably different anyway.
    The speedo needle rapidly fluctuates back and forth by 20-30km'h when driving. The odometer works fine, as far as I can tell.
    The problem is much worse at lower speeds - at speeds above about 80 (indicated) it settles right down...
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    If the odometer is working correctly, it won't be a slipping drive. The most likely problem is a kinked speedo cable, or possibly just dry, and very unlikely, has a loose strand.
    Aussie Expat in NZ
    I had this - it got progressively worse until the speedo died completely.
    The cable was frayed out on the inside and broke. I got a new one on ebay for next to nothing - it took less than 5min to swap it over.
    Jul 2007
    Melbourne, VIC
    Replace the speedo cable first. It's fairly cheap and doesn't take too long.
    That's what I did with mine and it made a huge difference to the wildly swinging needle.
    Next it will be the speedo but so far so good.
    Sunshine Coast
    Yeah, I'd replace the speedo cable too - it's cheap and in my experience with the same symptoms fixed the problem.
    Sussex Inlet. N.S.W.
    Is it possible to just change the inner cable or should you change the whole unit? Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    JDNSW's Avatar
    Quote Originally Posted by jx2mad View Post
    It is possible - but I have not seen just the inner sold for many years!
    Jul 2007
    Melbourne, VIC
    Replace the whole cable.
    It relies upon running freely which you wont be able to guarantee when using the old speedo cable sheath. It may be filled with gunk or worn internally.
    VladTepes's Avatar
    Bracken Ridge, Qld
    Where does one obtian a cheap Defender speedo cable from ?
    gone
    1996 Discovery 1
    current
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    Quote Originally Posted by VladTepes View Post
    at the cheap Defender speedo cable shoppe just up the road from you ole salt.....
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
