 Master
						Master
						Folks I put the new housing on, tipped some diesel into the filter prior to screwing it back on to try and help get it sucking fuel into the motor but nothing. Turned the ignition on and off heaps of times then cranked it over in an attempt to get her going any more and I will drain the battery. What else can I do. It's driving me mad After the tow on Friday and now with new filter housing attached she won't go
 Master
						Master
						Only other things I can think of is to check your conections again.
One might be sucking air?
Silly I know but are they all on the right spots?(check agaist your pic maybe).
Drop the filter and see if the fuel has gone, might have to refill it a few times.
Any one know the bleeding method for this beast???
My thought is turn the key till the pump stops, turn off key and repeat till the pump noise changes(slows up,works harder).
A special priming tool is required:
Links and Downloads Manager - Australian Land Rover Owners
discussed here:
Defender2 - View topic - Puma fuel bleeding pump
Not so simple with out the right tool.
Mahn England
Ex 300Tdi Disco:
 Master
						Master
						Thanks Al my friend that put the housing back on is a mechanic so that parts right. I will drop the filter tommorow again. It's very hard almost negligble in picking a pump noise with turning the ignition on and off. Wife is now giving me a hard time saying I should have bought a normal car...... Picked up Friday and now not driveable tried explaining all new diesels would be the same but all she sees is a stranded Defender.
 Master
						Master
						1998 Defender
2008 Madigan
2010 Cape York
2012 Beadell, Bombs and other Blasts
2014 Centreing the Simpson
VKS-737 mob 7669
another happy thread about pumas
it even takes abit to start even with the hand pump,
looks like its time for the old stand by of pressurizing the fuel tank and dropping the return line.
gee a brand new vehicle that requires 1960's tricks to fix.
youd have thought that ford would have learnt about this from when the engine was in the transit. letting it go into a vehicle thats going to get in situation where the fuel system could pick up air (ie off road angles and low fuel) is just criminal.
the backup stand by trick (which is an old detroit trick) is to crack the self sealing fitting by opening it with a screw driver while the engine is off and then cranking it (or letting the electric pump run) till the fuel runs out clear(ish)
