Results 1 to 10 of 16
Thread: Steering box leaking fluid
    Castle Hill, Sydney, Australia
    It looks like a seal on the shaft that comes out of the bottom of the box, has gone. I have a slow but steady drip.
    My manual does not cover the steering box for the V8 1985 County, but I assume if you take the steering arm off you can remove the old seal and put a new one in.
    Has anyone been through this pain recently?
    Qld.
    Hello Jim,
    Well, in so much as my newish Defender has **** it's steering box, I too have been through this pain recently - but not in terms of fixing the issue. Land Rover Australia can pick up the tab for that one.
    But isn't it odd - steering boxes seem to be a Land Rover weakness - who'd have thought this possible?
    So - unfortunately, I can't provide any instructive comments on the fix - but hopefully this "bump" will provide you with an answer.
    Good luck.
    2007 Defender 110
    1993 BMW R100LT
    NSW far north coast
    The quick way to get a seal out of a 4 bolt 'box.
    (should work in the earlier ones too)
    Undo the drop arm (if you can), pop off the dust seal, undo the circlip, slip the drop arm back on and do the nut up lightlyy, put a big tray under the steering box, turn the engine on and wind the steering to full lock and once the seal blows, shut the engine down very quickly.
    Install new seal (wrap output shaft threads and spline with masking or electrical tape before sliding seal on) and re-assemble components
    clean32 is offline AULRO Holiday Reward Points Winner!
    SA, Newton
    Mate
    first thing you need to check out is if it is a 3 boult or 4. all the latter ones are 4 but a 85 will be a 3 unless it has been swaped out.
    there are quite a few difrences between the 2, the 4 suposably is stronger the 3 is more likley to get you home, not that there are storys about the 4 leaving you stranded.
    any way the 3 has 2 seals up there.
    check it out and i can scan the 3 exsploded diagram or 4 for that matter
    Thanks to all for supportive comments and suggestions.
    Clean32,
    I have a 4 bolt box if that means there are 4 bolts attaching it to the chassis. I will really appreciate an exploded diagram so I can see where I am going with this.
    Jim
    NSW far north coast
    Quote Originally Posted by Carslil Jim View Post
    Clean32,
    Jim
    No, three and four bolt refers to the number of bolts on the top cover assembly.
    I have a four bolt drawing but no three (that I can copy easily), but it looks like C32 has a three bolt drawing.
    With the three bolt it looks like you pop the circlip first, the dust cover/supplementary seal is above that, then the main seal as C32 said.
    richard4u2 Guest
    you have to find out what caused the seal to leak , is the sharft damaged ? which is most probably the case so repacing the seal will only be a temp fix
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    can help put it off for quite some time
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Thanks again for suggestions.
    I have a three bolt steering box if you count the bolts that hold the "lid" down. There is an additional smaller bolt towards the centre (bleed?), and an adjuster in the centre.
    I sure would like a diagram showing the seal(s) at bottom of the box if anyone has it.
    SA, Newton
    bottom right,
