3.5V8 - Dual Fuel Timing
					The troublesome 24v ignition system on my 101 has been ripped out and has been replaced with a holden bosch dissy with an early electronic system fitted.  The engine (3.5 carby V8) also runs LPG and when installing the new dissy I set up the static timing at the listed 3 degrees BTDC for petrol as I do not know what to set it up on for dual fuel.  It runs OK just a little down on power.
So first question - what is the static timing setting for just LPG and what should it be for dual fuel.  If I were to set it up to the 'just LPG' setting what would the impact be if I had to run on petrol?
Second question - ultimately I want to buy a more modern ignition system for the dissy, one that will switch ignition timing settings when switching from petrol to lpg etc.  Any suggestions on something that might be suitable would be appreciated - also how hard are they to program or do they come pre-programmed.
