Results 1 to 10 of 11
Thread: FL1 thermostat mod
    Bathurst NSW
    FL1 thermostat mod
    Hey guys, been reading a few threads on the FL1, the cheap prices of the 1.8L petrol models is tempting as we are looking at replacing stacey's pajero with something smaller. Im thinking of buying one and then planning an engine swap whilst I wait for the inevidable engine problems.
    Having said that I have read a few threads where Garrycol has mentioned a thermostat mod, im aware that the cooling system design, largely the position of the thermostat, is the cause of all the head issues. What does this mod entail and is there a kit that has been devised, i did a search but couldnt find any other threads.
    If i can buy one and do this straight away then i might get a few years of good motoring out of one.
    Matt
    <a href=https://the4wdzone.com.au/wp-content/uploads/logo.png target=_blank>https://the4wdzone.com.au/wp-content/uploads/logo.png</a>
    The 4wd Zone/Opposite Lock Bathurst
    263 Stewart Street, Bathurst, NSW
    http://www.the4wdzone.com.au/
    Discounts for AULRO members, just shoot me a PM before you purchase.
    Bathurst NSW
    I found this website, might be helpful, not having seen the layout of the motor in the freelander, i dont know if this type of kit would fit or if something similar would need to be devised.
    Cooling system modifications
    Bathurst NSW
    If one of these kits was installed you could just remove the original thermostat completely. Yes?
    Bathurst NSW
    Hunter Valley
    LR sell the updated remote thermostat. Part Number PCH001190. This hose is the top and bottom radiator hose with the thermostat in the middle. The Original thermostat is positioned under the inlet manifold in a coolant pipe. You can replace it with PN PEL000040 but is just a thermostat with the middle missing which you can just cut out of the old one.
    Bathurst NSW
    Quote Originally Posted by woko View Post
    how much does that part cost?
    Have people who have done this mod still experienced the cylinder head failure or does this actually fix the problem?
    Douglas Park, NSW
    Quote Originally Posted by Ace View Post
    From what I've seen, yes.
    BTW, I assume you mean liner/block failure. The heads are fine.
    Bathurst NSW
    yeah, thats what i meant scouse.
    So in reality the liners are flawed, the thermostat issue just speeds the process up.
    What is the cause of the liners slipping then?
    If you buy a 1.8L Petrol freelander and pull the motor is there something that can be done to prevent it?
    Hunter Valley
    Have been told you can fit the liners with devcon and the don't drop. Haven't tried it but looking how liners sit in block should work
    Bathurst NSW
    righto, thanks.
