I'd stick to OEM whils the vehicle is under warranty, and also use a torque wrench and socket when changing the filter and doing up the drain plug.
Oil filter cover: 35 Nm (26 lb.ft).
Drain plug: 23 Nm (17 lb.ft). (Should be replaced when oil changed)
